跳转到主内容
Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement
你所需要的
  1. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement, Wifi Chip: 步骤 1 中的图像 1,1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the five black 80mm Phillips #0 screws.
    • Remove the four black 50mm Phillips #0 screws.
  2. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: 步骤 2 中的图像 1,1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  3. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips J0 screwdriver to remove the one black 3mm screw.
  4. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: 步骤 4 中的图像 1,1
    • Use an up and away motion to pull the module out of its slot.
  5. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: 步骤 5 中的图像 1,1
    • Use precision tweezers to pry the black wire with a gold plug off the main gold plug on the module.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 670
