跳转到主内容
Asus VivoBook S200E-RHI3T73 Touchpad Replacement
你所需要的
  1. Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: 步骤 1 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: 步骤 1 中的图像 2,2
    • In order to remove the back lid, you must lay the laptop down with the lid closed and remove the screws with a Phillips #0 screwdriver.
    • There are five 80mm screws.
    • There are four 50mm screws.
    • Pull the back lid off of the laptop using your fingers.
  2. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 步骤 2 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 步骤 2 中的图像 2,2
    • There should be a total of twelve 50mm screws when removing the battery.
    • The battery does not have to be fully removed for this step, however the screws must be taken out and the battery lifted.
  3. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 步骤 3 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the six screws attached to the silver panel.
    • Disconnect the LED ribbon wires using a spudger to lift the clamp.
  4. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 步骤 4 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the four screws on the silver panel.
    • Using a spudger, gently lift the silver ground strips off of the touch pad.
    • Pull the touch pad up and towards the battery to remove it from the laptop.
结论
团队
IUPUI, Team S9-G9, Wilson Spring 2019 IUPUI, Team S9-G9, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S9G9
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 735
