跳转到主内容
Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement
你所需要的
  1. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  2. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 2 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 2 中的图像 2,2
    • Using the same Phillips #0 screwdriver, remove the eight black 50mm screws surrounding the battery.
  3. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 3 中的图像 1,1
    • Using a set of precision tweezers, lift the motherboard connector tab.
  4. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 4 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 4 中的图像 2,2
    • Use a nylon spudger or your fingers to gently pry the battery up.
    • Remove the battery.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  5. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): 步骤 5 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the nine 50mm panel screws.
    • Gently remove back panel
    • Be aware of sharp metal edges once the panel is removed.
  6. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 6 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  7. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 7 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 7 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the five 5mm screws on the fan.
    • Peel the protective wire tape off of the multicolored wires.
  8. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 8 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 8 中的图像 2,2
    • Use the precision tweezers to disconnect the wires and gently remove the fan.
    • Be gentle so as not to break wires.
  9. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 9 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 步骤 9 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the eight 6mm PCB board screws.
    • Remove the PCB board.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 329
