跳转到主内容
Asus VivoBook S200E-RHI3T73 Motherboard Replacement
你所需要的
  1. Asus VivoBook S200E-RHI3T73 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  2. Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 2 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using the same Phillips #0 screwdriver, remove the eight black 50mm screws surrounding the battery.
  3. Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using a set of precision tweezers, lift the motherboard connector tab.
  4. Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 4 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a nylon spudger or your fingers to gently pry the battery up.
    • Remove the battery.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  5. Asus VivoBook S200E-RHI3T73 Motherboard Replacement, Printed Circuit Board (PCB): 步骤 5 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the nine 50mm panel screws.
    • Gently remove back panel
    • Be aware of sharp metal edges once the panel is removed.
  6. Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  7. Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 7 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the five 5mm screws on the fan.
    • Peel the protective wire tape off of the multicolored wires.
  8. Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 8 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the precision tweezers to disconnect the wires and gently remove the fan.
    • Be gentle so as not to break wires.
  9. Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 9 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the eight 6mm PCB board screws.
    • Remove the PCB board.
  10. Asus VivoBook S200E-RHI3T73 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Using the Phillips#0 screwdriver, unscrew the 3.5mm screws surrounding the motherboard.
  11. Asus VivoBook S200E-RHI3T73 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Gently lift the motherboard and remove it from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 827
