跳转到主内容
Asus VivoBook S200E-RHI3T73 Keyboard Replacement
你所需要的
  1. Asus VivoBook S200E-RHI3T73 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the nine 50mm screws and lift the panel.
    • Be aware of sharp metal edges once the panel is removed.
  2. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the twelve 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  3. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: 步骤 3 中的图像 1,3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: 步骤 3 中的图像 2,3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the five 5mm screws around the fan.
    • Use the precision tweezers to unplug the fan cords.
    • Be cautious of pulling the cords.
  4. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: 步骤 4 中的图像 1,3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: 步骤 4 中的图像 2,3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Use the Phillips#0 screwdriver to unscrew the 3.5mm screws from around the motherboard and the 6mm screws from around the PCB.
    • Double check for unloosened screws. Bending the boards can damage the hardware.
  5. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: 步骤 5 中的图像 1,2 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Use the Phillips#0 screwdriver to remove the 50mm screws on the boarder of the metal panel.
    • Be cautious of sharp metal edges.
    • Carefully remove the panel. Without care it will bend and be difficult to reassemble.
  6. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Using the Phillips#0 screwdriver, remove the 50mm screws surrounding the keyboard.
    • Gently remove the keyboard.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 594
