跳转到主内容
Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement
你所需要的
  1. Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: 步骤 2 中的图像 1,2 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: 步骤 3 中的图像 1,2 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing.
  4. Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: 步骤 4 中的图像 1,3 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: 步骤 4 中的图像 2,3 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Lift the hard drive up and remove the power supply cable connected to it.
    • Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
  5. Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: 步骤 5 中的图像 1,3 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: 步骤 5 中的图像 2,3 Asus VivoBook Q302LA-BHI3T09 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Carefully peel back and remove the plastic hard drive cover to reveal the two 3.0 mm screws on the hard drive casing.
    • Using a JIS #0 screwdriver, unscrew the two 3.0 mm screws on the side of the metal casing to remove the hard drive itself.
结论
2等其他人完成本指南。
Deric Wright
于02/14/18注册
636 声望
创作了3篇指南
团队
USF Tampa, Team S5-G5, Eyestone Spring 2018 USF Tampa, Team S5-G5, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 872
