跳转到主内容
Asus VivoBook Q302LA-BHI3T09 Fan Replacement
你所需要的
  1. Asus VivoBook Q302LA-BHI3T09 Fan Replacement, Fan: 步骤 1 中的图像 1,2 Asus VivoBook Q302LA-BHI3T09 Fan Replacement, Fan: 步骤 1 中的图像 2,2
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
  2. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: 步骤 2 中的图像 1,2 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: 步骤 2 中的图像 2,2
    • Pry open the back casing using the opening tool along the side crevice.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: 步骤 3 中的图像 1,3 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: 步骤 3 中的图像 2,3 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: 步骤 3 中的图像 3,3
    • Remove the following screws that mount the fan and heatsink to the motherboard:
    • Three 3.0 mm screws for the fan
    • Four 2.0 mm screws for the heatsink
    • The bottom of the heatsink will contain thermal paste. Avoid making contact with this as any dirt or oils can reduce the effectiveness of the cooler.
结论
团队
USF Tampa, Team S5-G5, Eyestone Spring 2018 USF Tampa, Team S5-G5, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 155
