跳转到主内容
Asus VivoBook Q200E-BSI3T08 Trackpad Replacement
你所需要的
  1. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 2 中的图像 1,1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 3 中的图像 1,2 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 5 中的图像 1,3 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 5 中的图像 2,3 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 5 中的图像 3,3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 6 中的图像 1,2 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 6 中的图像 2,2
    • Now just lift the battery out of place.
  7. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Trackpad: 步骤 7 中的图像 1,1
    • Disconnect the small blue TP(trackpad) labeled data bus.
  8. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 8 中的图像 1,1
    • Identify the ten 2.94mm screws on the metal bracket.
  9. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 9 中的图像 1,1
    • Unscrew the ten 2.94mm screws with the Philips #00 Head.
  10. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 10 中的图像 1,1
    • Remove all of the metallic tape holding the metal bracket to the components surrounding it.
  11. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 11 中的图像 1,1
    • Lift the metal bracket away from the laptop.
  12. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 12 中的图像 1,1
    • Unscrew the four 3.5mm screws with Phillips #00 Head.
    • This black plastic panel holds the trackpad in place.
  13. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 步骤 13 中的图像 1,1
    • Lift the trackpad up from the laptop and slide it out of the housing.
结论
Mitchell Jackson
于05/17/17注册
742 声望
创作了7篇指南
团队
IUPUI, Team S4-G4, Wilson Summer 2017 IUPUI, Team S4-G4, Wilson Summer 2017 的会员
IUPUI-WILSON-SU17S4G4
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 566
