跳转到主内容
Asus VivoBook Q200E-BSI3T08 Motherboard Replacement
你所需要的
  1. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 3 中的图像 1,2 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 5 中的图像 1,3 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 5 中的图像 2,3 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 5 中的图像 3,3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 6 中的图像 1,2 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Now just lift the battery out of place.
  7. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Cooling Fan: 步骤 7 中的图像 1,1
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  8. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Unplug the power bus for the fan.
  9. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Lift up and remove the cooling fan from the slot.
  10. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Wireless Card: 步骤 10 中的图像 1,2 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Wireless Card: 步骤 10 中的图像 2,2
    • Locate wireless card next to battery.
  11. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the one 4.9mm screw that holds the wireless card in place with a Phillips #00 screwdriver.
  12. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Unplug the black coaxial cable from the wireless card.
  13. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Pull the wireless card from connector slot.
  14. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement, Motherboard: 步骤 14 中的图像 1,1
    • Locate the motherboard under the cooling fan.
  15. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Unscrew the two 5.9mm screws on the PCB board with a Phillips #0 screwdriver.
  16. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Remove the PCB board from the motherboard.
  17. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Unscrew the four 5.9mm hard drive bracket screws with a Phillips #0 screwdriver.
  18. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 18 中的图像 1,2 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 18 中的图像 2,2
    • Unscrew the four 5.9mm screws with a Phillips #0 screwdriver.
    • Next, carefully lift the LAN bracket out of the slot.
  19. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 19 中的图像 1,1
    • Remove the five 5.9mm screws holding the motherboard in place with a Phillips #0 screwdriver.
    • Remove the five 3.5mm screws holding the motherboard with a Phillips #00 screwdriver.
  20. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 20 中的图像 1,1
    • Carefully lift the motherboard up out of the slot.
  21. Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 21 中的图像 1,2 Asus VivoBook Q200E-BSI3T08 Motherboard Replacement: 步骤 21 中的图像 2,2
    • Locate and unplug the power bus from the motherboard.
    • The motherboard can now be replaced.
结论
Mitchell Jackson
于05/17/17注册
742 声望
创作了7篇指南
团队
IUPUI, Team S4-G4, Wilson Summer 2017 IUPUI, Team S4-G4, Wilson Summer 2017 的会员
IUPUI-WILSON-SU17S4G4
4 名成员
创作了7篇指南
一条评论
Very useful tutorial with nice photos indicating even different type of screws n different color..
This was more useful than a YouTube video..
I just replaced my mother board..
Thank you and God bless u for ur effort..
Gs Mobile - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 2,195
