跳转到主内容
Asus VivoBook Q200E-BSI3T08 Display Replacement
你所需要的
  1. Asus VivoBook Q200E-BSI3T08 Display Replacement, Display: 步骤 1 中的图像 1,2 Asus VivoBook Q200E-BSI3T08 Display Replacement, Display: 步骤 1 中的图像 2,2
    • First open the laptop and place it so that you have access to the side of the display.
    • Next you want to place the laptop in a position where you have easy access to the display.
    • Use a metal or a plastic prying tool to split the front and back of the display.
    • Start on the side and work your way around.
  2. Asus VivoBook Q200E-BSI3T08 Display Replacement: 步骤 2 中的图像 1,2 Asus VivoBook Q200E-BSI3T08 Display Replacement: 步骤 2 中的图像 2,2
    • Pull the clear plastic display down from the bottom right and left.
    • If pulled from the top you might crack the actual plastic.
  3. Asus VivoBook Q200E-BSI3T08 Display Replacement: 步骤 3 中的图像 1,1
    • Remove the two 2.8mm screws on the top right and top left of the screen using a Phillips #0 screwdriver.
  4. Asus VivoBook Q200E-BSI3T08 Display Replacement: 步骤 4 中的图像 1,1
    • Remove the two 2.8 screws on the bottom right and left using a Phillips #0 screwdriver.
  5. Asus VivoBook Q200E-BSI3T08 Display Replacement: 步骤 5 中的图像 1,1
    • Once the screws are removed you should be able to move the display down. Be careful as there is a connection to the motherboard which will need to be removed.
  6. Asus VivoBook Q200E-BSI3T08 Display Replacement: 步骤 6 中的图像 1,1
    • Here is a picture of the connection that needs to be removed to free the display.
    • Pull connection from the plastic on the sides not the wires as these are fragile.
  7. Asus VivoBook Q200E-BSI3T08 Display Replacement: 步骤 7 中的图像 1,2 Asus VivoBook Q200E-BSI3T08 Display Replacement: 步骤 7 中的图像 2,2
    • Once this connection is removed here's what that should look.
  8. Asus VivoBook Q200E-BSI3T08 Display Replacement: 步骤 8 中的图像 1,1
    • Remove display and place your new one in it's place.
结论
Mitchell Jackson
于05/17/17注册
742 声望
创作了7篇指南
团队
IUPUI, Team S4-G4, Wilson Summer 2017 IUPUI, Team S4-G4, Wilson Summer 2017 的会员
IUPUI-WILSON-SU17S4G4
4 名成员
创作了7篇指南
一条评论
You are suppose to remove the hinge/screen assembly from the laptop chasis before starting step 1, if you don't you will break the digitizer author please fix the guide
Nicholas Chan - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 8
总计 1,842
