跳转到主内容
Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement
你所需要的
  1. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement, Hard Disk Drive: 步骤 1 中的图像 1,1
    • Disconnect laptop from the power supply.
  2. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the ten 6.4 mm screws from the bottom cover.
  3. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: 步骤 3 中的图像 1,2 Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: 步骤 3 中的图像 2,2
    • Use a metal or nylon spudger to pry open the back cover on all sides.
    • Remove the back cover to access the inside where the hard disk drive is located.
  4. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: 步骤 4 中的图像 1,1
    • Locate the hard-drive.
    • Disconnect the hard disk drive from its connectors, and remove the drive.
    • Place the new HDD in the same location and orientation.
结论
另外一个人完成了本指南。
Justin Martel
于03/22/22注册
159 声望
撰写一个指南
团队
UMass Dartmouth, Team 7-2, Sinclaire Spring 2022 UMass Dartmouth, Team 7-2, Sinclaire Spring 2022 的会员
UMASSD-SINCLAIRE-S22S7G2
5 名成员
创作了2篇指南
一条评论
Hey, do you by any chance have the reference for the battery in the Asus TP410U ? Thank you!
Matt JBOM - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 35
总计 1,383
