跳转到主内容
Asus VivoBook E203MA-TBCL432B Power Button Replacement
你所需要的
  1. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Power Button Replacement: 步骤 2 中的图像 1,3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: 步骤 2 中的图像 2,3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Power Button Replacement: 步骤 3 中的图像 1,3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: 步骤 3 中的图像 2,3 Asus VivoBook E203MA-TBCL432B Power Button Replacement: 步骤 3 中的图像 3,3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: 步骤 4 中的图像 1,2 Asus VivoBook E203MA-TBCL432B Power Button Replacement, Power Button: 步骤 4 中的图像 2,2
    • Remove the single connector by first pulling back the white tab and then pulling the connector out with the blue tab.
  5. Asus VivoBook E203MA-TBCL432B Power Button Replacement: 步骤 5 中的图像 1,2 Asus VivoBook E203MA-TBCL432B Power Button Replacement: 步骤 5 中的图像 2,2
    • Remove the single 2 mm screw with a Phillips #0 screwdriver.
  6. Asus VivoBook E203MA-TBCL432B Power Button Replacement: 步骤 6 中的图像 1,1
    • Now that the power button component is free, lift it up and out of the laptop.
结论
Jacob Aubertine
于03/21/19注册
470 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 895
