简介
If you need a new battery on your Asus F412DA laptop here is a guide on how to do it.
你所需要的
在这个步骤中使用的工具:Anti-Static Wrist Strap$7.95
Start by removing the marked screws
Remove the four 6mm screws
Remove the two 8mm screws
Remove the four 9mm screws
Using a opening tool, pry and lift at the edge of the bottom until you feel it open.
Using a fingernail or spudger move back the retaining clip holding the battery connector in place.
Put a spudger under the battery connector and twist, the connector should lift off.
To reassemble your device, insert the new battery and follow these instructions in reverse order.
3等其他人完成本指南。
