跳转到主内容
Asus V6800V Wireless Card Replacement
你所需要的
  1. Asus V6800V Wireless Card Replacement, Battery: 步骤 1 中的图像 1,2 Asus V6800V Wireless Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Wireless Card Replacement, Wireless Card: 步骤 2 中的图像 1,2 Asus V6800V Wireless Card Replacement, Wireless Card: 步骤 2 中的图像 2,2
    • Remove the six screws highlighted on the picture.
    • Once the screws are removed, pry open the panel with the pry tool.
    • It should now look like this.
  3. Asus V6800V Wireless Card Replacement: 步骤 3 中的图像 1,2 Asus V6800V Wireless Card Replacement: 步骤 3 中的图像 2,2
    • After removing that panel, locate the screw on the right as highlighted.
    • Remove that screw.
    • Pry open the side panel with the small prying tool as shown.
    • That panel should pop off and the wireless card will now be easily visible.
  4. Asus V6800V Wireless Card Replacement: 步骤 4 中的图像 1,1
    • Place the small prying tool underneath the gold connector and gently apply pressure straight up until it pops off.
    • Repeat for the other one.
    • Place the gold connectors aside.
  5. Asus V6800V Wireless Card Replacement: 步骤 5 中的图像 1,3 Asus V6800V Wireless Card Replacement: 步骤 5 中的图像 2,3 Asus V6800V Wireless Card Replacement: 步骤 5 中的图像 3,3
    • Locate the tabs that are holding the wireless card in place. These are highlighted in picture.
    • Place one finger on each tab and press each to the side away from the wireless card as shown.
    • The wireless card should pop up as shown. Pull up more with fingers to get more clearance.
  6. Asus V6800V Wireless Card Replacement: 步骤 6 中的图像 1,2 Asus V6800V Wireless Card Replacement: 步骤 6 中的图像 2,2
    • To remove the wireless card, pull the card directly out.
    • It should come out with just a little bit of pressure.
    • It should look as shown when removed.
结论
Steven
于06/24/10注册
32 声望
创作了2篇指南
团队
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G9
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 3,875
