当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
The actual battery is not pictured.
Using a Phillips #0 screwdriver, remove the two screws from the case.
These screws should have a "K" symbol next to them.
Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
Once all four tabs have been released, the top half of the keyboard should be free.
Using a Phillips #0 screwdriver, remove the screws at the bottom of the chassis to remove the top panel.
This will allow the lower case to be removed from the rest of the computer.
Use your fingernails or a pry tool to gently separate both halves of the case. Begin at the front and work around the entire case.
Be cautious not to damage the cables that connect both sides of the case.
Remove the internal cables from front to back.
Use your fingers to gently remove the cables from their sockets.
The cables that connect the display to the main chassis are difficult to pull out using your fingers. A tool, such as tweezers, may be needed.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
