跳转到主内容
Asus V6800V Speakers Replacement
你所需要的
  1. Asus V6800V Speakers Replacement, Battery: 步骤 1 中的图像 1,2 Asus V6800V Speakers Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Speakers Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the two screws from the case.
    • These screws should have a "K" symbol next to them.
  3. Asus V6800V Speakers Replacement: 步骤 3 中的图像 1,3 Asus V6800V Speakers Replacement: 步骤 3 中的图像 2,3 Asus V6800V Speakers Replacement: 步骤 3 中的图像 3,3
    • Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
    • Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
    • Once all four tabs have been released, the top half of the keyboard should be free.
  4. Asus V6800V Speakers Replacement: 步骤 4 中的图像 1,2 Asus V6800V Speakers Replacement: 步骤 4 中的图像 2,2
    • Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
    • Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
  5. Asus V6800V Speakers Replacement, Lower Case: 步骤 5 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the screws at the bottom of the chassis to remove the top panel.
    • This will allow the lower case to be removed from the rest of the computer.
  6. Asus V6800V Speakers Replacement: 步骤 6 中的图像 1,1
    • Remove the six screws from below the keyboard with a Phillips #0 screwdriver.
  7. Asus V6800V Speakers Replacement: 步骤 7 中的图像 1,2 Asus V6800V Speakers Replacement: 步骤 7 中的图像 2,2
    • Use your fingernails or a pry tool to gently separate both halves of the case. Begin at the front and work around the entire case.
    • Be cautious not to damage the cables that connect both sides of the case.
  8. Asus V6800V Speakers Replacement: 步骤 8 中的图像 1,3 Asus V6800V Speakers Replacement: 步骤 8 中的图像 2,3 Asus V6800V Speakers Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the internal cables from front to back.
    • Use your fingers to gently remove the cables from their sockets.
    • The cables that connect the display to the main chassis are difficult to pull out using your fingers. A tool, such as tweezers, may be needed.
  9. Asus V6800V Speakers Replacement: 步骤 9 中的图像 1,1
    • After separating the top and bottom halves of the case, lay them flat on the work area.
  10. Asus V6800V Speakers Replacement, Speakers: 步骤 10 中的图像 1,3 Asus V6800V Speakers Replacement, Speakers: 步骤 10 中的图像 2,3 Asus V6800V Speakers Replacement, Speakers: 步骤 10 中的图像 3,3
    • Remove the four screws using a Phillips #0 screwdriver.
    • Remove the protective metal plates with your hands.
  11. Asus V6800V Speakers Replacement: 步骤 11 中的图像 1,3 Asus V6800V Speakers Replacement: 步骤 11 中的图像 2,3 Asus V6800V Speakers Replacement: 步骤 11 中的图像 3,3
    • Make sure all cables and wires are disconnected.
    • Remove the speakers from the case with your hands.
结论
另外一个人完成了本指南。
Jong Park
于06/24/10注册
114 声望
创作了5篇指南
团队
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G9
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 3,160
