跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Asus V6800V Keyboard Replacement
你所需要的
  1. Asus V6800V Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Asus V6800V Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the two screws from the case.
    • These screws should have a "K" symbol next to them.
  3. Asus V6800V Keyboard Replacement: 步骤 3 中的图像 1,3 Asus V6800V Keyboard Replacement: 步骤 3 中的图像 2,3 Asus V6800V Keyboard Replacement: 步骤 3 中的图像 3,3
    • Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
    • Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
    • Once all four tabs have been released, the top half of the keyboard should be free.
  4. Asus V6800V Keyboard Replacement: 步骤 4 中的图像 1,2 Asus V6800V Keyboard Replacement: 步骤 4 中的图像 2,2
    • Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
    • Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
结论
Steven
于06/24/10注册
32 声望
创作了2篇指南
团队
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G9
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 4,929
