简介
Removing the keyboard is a useful way to clean it, or it can be replaced if broken.
The keyboard needs to be removed if you wish to remove the top part of the case for further maintenance of the computer.
配件
无需配件。
First, the screws on the bottom need to be removed first.
  • First, the screws on the bottom need to be removed first.
添加评论
There are 4 small tabs holding the keyboard in place. These are located above the F1, F5, F10, and Ins keys. pic 69
  • There are 4 small tabs holding the keyboard in place. These are located above the F1, F5, F10, and Ins keys. pic 69
添加评论
Starting on one side, use a finger or small tool to press the tab into the chassis of the computer. The edge of the keyboard will elevate. 72, 73 Starting on one side, use a finger or small tool to press the tab into the chassis of the computer. The edge of the keyboard will elevate. 72, 73
  • Starting on one side, use a finger or small tool to press the tab into the chassis of the computer. The edge of the keyboard will elevate. 72, 73
添加评论
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
Continue down the keyboard. The keyboard will be noticeably elevated. 82, 83
  • Continue down the keyboard. The keyboard will be noticeably elevated. 82, 83
添加评论
Once all of the tabs are indented, the keyboard will eject itself, remaining elevated. 388
  • Once all of the tabs are indented, the keyboard will eject itself, remaining elevated. 388
添加评论
Partially remove the keyboard by sliding the elevated keyboard towards the screen. Don't remove it all of the way, as we need to remove it's cable first. 389
  • Partially remove the keyboard by sliding the elevated keyboard towards the screen. Don't remove it all of the way, as we need to remove it's cable first. 389
添加评论
To remove the cable holding the keyboard in, flip the keyboard upside down. 391 Using your forefinger and thumb, pinch both sides of the cable and pull away from the connector. 396, 401 You now have the keyboard separated from the computer. If you wish to clean it, you can use compressed air to blow the dirt out. You now have the keyboard separated from the computer. If you wish to clean it, you can use compressed air to blow the dirt out.
  • To remove the cable holding the keyboard in, flip the keyboard upside down. 391 Using your forefinger and thumb, pinch both sides of the cable and pull away from the connector. 396, 401
  • You now have the keyboard separated from the computer. If you wish to clean it, you can use compressed air to blow the dirt out.
添加评论
结论
6等其他人完成本指南。
Brian Tubb
于2010年06月24日注册
280 信誉积分
创作了3篇指南
团队
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G9
5 名成员
创作了11篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 10
总计 2,181
