跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Asus V6800V Fan Replacement
你所需要的
  1. Asus V6800V Fan Replacement, Battery: 步骤 1 中的图像 1,2 Asus V6800V Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Fan Replacement, Fan: 步骤 2 中的图像 1,2 Asus V6800V Fan Replacement, Fan: 步骤 2 中的图像 2,2
    • Remove highlighted screws, pry open case at highlighted spot.
  3. Asus V6800V Fan Replacement: 步骤 3 中的图像 1,2 Asus V6800V Fan Replacement: 步骤 3 中的图像 2,2
    • There are red, yellow, and black set of wires going to a white connector. Grab the three cables and pull straight up, away from the computer.
    • Make sure not to pull wires from connector. White connector should pop off with very little force.
  4. Asus V6800V Fan Replacement: 步骤 4 中的图像 1,2 Asus V6800V Fan Replacement: 步骤 4 中的图像 2,2
    • Remove screws highlighted.
  5. Asus V6800V Fan Replacement: 步骤 5 中的图像 1,2 Asus V6800V Fan Replacement: 步骤 5 中的图像 2,2
    • Fan should come up very easily. Grab the set of wires that you disconnected earlier and pull straight up.
    • In our pictured fan, there are a few pieces missing.
  6. Asus V6800V Fan Replacement: 步骤 6 中的图像 1,2 Asus V6800V Fan Replacement: 步骤 6 中的图像 2,2
    • Use a cotton swab to remove dust. Also you can use compressed air, blow air from the inside out to clear dust from vent, or heat sink.
结论
Jong Park
于06/24/10注册
114 声望
创作了5篇指南
团队
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G9
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 4,948
