跳转到主内容
Asus V6800V Fan Replacement
你所需要的
  1. Asus V6800V Fan Replacement, Battery: 步骤 1 中的图像 1,2 Asus V6800V Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Fan Replacement, Fan: 步骤 2 中的图像 1,2 Asus V6800V Fan Replacement, Fan: 步骤 2 中的图像 2,2
    • Use the Phillips #0 to remove the six screws on the back of the device.
    • Gently open the cover using the tab located by the highlighted box.
  3. Asus V6800V Fan Replacement: 步骤 3 中的图像 1,2 Asus V6800V Fan Replacement: 步骤 3 中的图像 2,2
    • Unplug the wires by pulling straight up on the white connector and away from the computer.
    • Make sure not to pull on the wires (as shown in the second picture). The white connector should pop off with very little force.
  4. Asus V6800V Fan Replacement: 步骤 4 中的图像 1,2 Asus V6800V Fan Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #0 to remove the three screws holding the fan in place.
  5. Asus V6800V Fan Replacement: 步骤 5 中的图像 1,2 Asus V6800V Fan Replacement: 步骤 5 中的图像 2,2
    • Remove the fan from the device.
    • The fan should remove easily.
  6. Asus V6800V Fan Replacement: 步骤 6 中的图像 1,2 Asus V6800V Fan Replacement: 步骤 6 中的图像 2,2
    • Use a cotton swab or compressed air to blow air from the inside, out to clear dust from the vent or heat sink.
结论
Jong Park
于06/24/10注册
114 声望
创作了5篇指南
团队
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G9
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 8
总计 4,998
