跳转到主内容
Asus V6800V CD/DVD Drive Replacement
你所需要的
  1. Asus V6800V CD/DVD Drive Replacement, Battery: 步骤 1 中的图像 1,2 Asus V6800V CD/DVD Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V CD/DVD Drive Replacement, Hard Drive: 步骤 2 中的图像 1,2 Asus V6800V CD/DVD Drive Replacement, Hard Drive: 步骤 2 中的图像 2,2
    • Remove the two screws using a Phillips #0 screwdriver.
  3. Asus V6800V CD/DVD Drive Replacement: 步骤 3 中的图像 1,2 Asus V6800V CD/DVD Drive Replacement: 步骤 3 中的图像 2,2
    • Pry open the case using an iFixit opening tool.
    • Actual hard drive is not shown in the second image.
  4. Asus V6800V CD/DVD Drive Replacement: 步骤 4 中的图像 1,2 Asus V6800V CD/DVD Drive Replacement: 步骤 4 中的图像 2,2
    • The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
    • Second image shows what it should look like once you remove the hard drive.
  5. Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: 步骤 5 中的图像 1,2 Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: 步骤 5 中的图像 2,2
    • Remove the screw from the bottom right corner using a Phillips #0 screwdriver.
    • Insert a spudger into the hole to carefully push the CD/DVD drive out.
结论
To reassemble your device, just push the new CD/DVD driver back. Then put the components back together then put the screws back in.
Jong Park
于06/24/10注册
114 声望
创作了5篇指南
团队
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 的会员
CPSU-JOHANN-R10S2G9
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 4,260
