简介
In this guide, you will learn how to replace the Hard Drive found in the Asus V500CA-DB51T. This guide was made to help with replacing a broken or defective hard drive, and is an easy repair for any skill level.
你所需要的
Remove the following ten screws securing the lower case to the upper case:
The top left and right corners have .7 cm screws.
The two top-middle and four bottom are .4 cm screws.
The middle left and right are .8 cm screws.
Remove the screws using the Phillips #00 screwdriver.
Remove the following screws securing the battery connector board to the logic board:
The red screws are size 2.3 cm T6 Torx
The orange screws are size 2.4 cm T6 Torx
