跳转到主内容
Asus V500CA-DB51T Hard Drive Replacement
你所需要的
  1. Asus V500CA-DB51T Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Asus V500CA-DB51T Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T Hard Drive Replacement: 步骤 2 中的图像 1,2 Asus V500CA-DB51T Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T Hard Drive Replacement: 步骤 4 中的图像 1,2 Asus V500CA-DB51T Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T Hard Drive Replacement: 步骤 5 中的图像 1,3 Asus V500CA-DB51T Hard Drive Replacement: 步骤 5 中的图像 2,3 Asus V500CA-DB51T Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,3 Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 2,3 Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 3,3
    • Remove the following screws securing the battery connector board to the logic board:
    • The red screws are size 2.3 cm T6 Torx
    • The orange screws are size 2.4 cm T6 Torx
  7. Asus V500CA-DB51T Hard Drive Replacement: 步骤 7 中的图像 1,2 Asus V500CA-DB51T Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Remove the SSD (Solid State Drive) assembly from the upper case.
结论
团队
UMass Dartmouth, Team S6-G2, Rockett Fall 2017 UMass Dartmouth, Team S6-G2, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S6G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 565
