跳转到主内容
Asus UL80VT Motherboard Replacement
你所需要的
  1. Asus UL80VT Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Motherboard Replacement: 步骤 2 中的图像 1,2 Asus UL80VT Motherboard Replacement: 步骤 2 中的图像 2,2
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Motherboard Replacement: 步骤 3 中的图像 1,1
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
  4. Asus UL80VT Motherboard Replacement, Hard Drive: 步骤 4 中的图像 1,3 Asus UL80VT Motherboard Replacement, Hard Drive: 步骤 4 中的图像 2,3 Asus UL80VT Motherboard Replacement, Hard Drive: 步骤 4 中的图像 3,3
    • Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Lift the panel from the device.
  5. Asus UL80VT Motherboard Replacement: 步骤 5 中的图像 1,2 Asus UL80VT Motherboard Replacement: 步骤 5 中的图像 2,2
    • Slide the hard drive away from the SATA connector and remove the hard drive from the device.
  6. Asus UL80VT Motherboard Replacement, RAM: 步骤 6 中的图像 1,1
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  7. Asus UL80VT Motherboard Replacement: 步骤 7 中的图像 1,3 Asus UL80VT Motherboard Replacement: 步骤 7 中的图像 2,3 Asus UL80VT Motherboard Replacement: 步骤 7 中的图像 3,3
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
  8. Asus UL80VT Motherboard Replacement, Keyboard: 步骤 8 中的图像 1,2 Asus UL80VT Motherboard Replacement, Keyboard: 步骤 8 中的图像 2,2
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  9. Asus UL80VT Motherboard Replacement: 步骤 9 中的图像 1,1
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
  10. Asus UL80VT Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Remove the nine 5 mm screws using the Phillips #0 screwdriver.
  11. Asus UL80VT Motherboard Replacement: 步骤 11 中的图像 1,1
    • Flip the laptop over and remove nine 5 mm screws using the Phillips #0 screwdriver.
  12. Asus UL80VT Motherboard Replacement: 步骤 12 中的图像 1,2 Asus UL80VT Motherboard Replacement: 步骤 12 中的图像 2,2
    • Use the iFixit opening tool to remove the cd drive on the left of the laptop.
  13. Asus UL80VT Motherboard Replacement: 步骤 13 中的图像 1,1
    • Use the same tool to remove the plastic top from the laptop.
  14. Asus UL80VT Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the eight 3 mm screws using the Phillips #0 screwdriver.
    • Lift up the motherboard and disconnect all wires attaching the motherboard to the rest of the computer.
  15. Asus UL80VT Motherboard Replacement: 步骤 15 中的图像 1,1
    • Lift the motherboard out of the laptop and remove it from the device.
结论
2等其他人完成本指南。
James DellaMorte
于03/08/19注册
660 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 437
