简介
The keyboard is the device used to input data, text, and commands through to your laptop. If the keyboard is not responding or inputs incorrectly, you may have to replace your keyboard. This guide will show you how to replace the keyboard.
你所需要的
Insert a plastic opening tool or a flat-head screwdriver between the laptop body and the keyboard.
Gently pry the keyboard up. This will allow you to unclip the keyboard.
Use an old plastic card or a similar flat object to prevent the keyboard from clipping back in while carefully working along the keyboard perimeter.
