跳转到主内容
简介
This guide will show how to remove and replace the RAM on your Asus U56E-BBL6 laptop.
配件
没有特定配件。
  1. Using a Phillips #00 screwdriver, remove the screws. Using a Phillips #00 screwdriver, remove the screws.
    • Using a Phillips #00 screwdriver, remove the screws.
  2. Lift backplate and remove from the case.
    • Lift backplate and remove from the case.
  3. PC 笔记本电池
    An easy fix for a big power boost.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  4. Once inside the panel, locate your RAM sticks.
    • Once inside the panel, locate your RAM sticks.
  5. This device is embedded with  two RAM sticks. Push the metal brackets carefully to release and remove the RAM stick .
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  6. Repeat the previous step for removing the other RAM stick. Repeat the previous step for removing the other RAM stick.
    • Repeat the previous step for removing the other RAM stick.
结论
另外一个人完成了本指南。
Josiah Allard
于2018年10月26日注册
705 信誉积分
创作了6篇指南
团队
UMass Dartmouth, Team S2-G8, Peak Fall 2018 UMass Dartmouth, Team S2-G8, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G8
3 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 66
