跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will take you through the process of replacing the optical drive in an Asus U56E-BBL6 laptop. You will need the correct replacement optical drive for your laptop to complete the installation.
  1. Make sure you unplugged the laptop before you begin the replacement process.
    • Make sure you unplugged the laptop before you begin the replacement process.
    • Locate the battery locking tabs on the upper right and left corner.
    • Press the tabs in towards each other.
  2. Pull the battery outwards to  remove it.
    • Pull the battery outwards to remove it.
  3. Using a Phillips #00 screwdriver, remove the screws. Using a Phillips #00 screwdriver, remove the screws.
    • Using a Phillips #00 screwdriver, remove the screws.
  4. Lift backplate and remove from the case.
    • Lift backplate and remove from the case.
  5. Once inside the panel, locate your RAM sticks.
    • Once inside the panel, locate your RAM sticks.
  6. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  7. This device is embedded with  two RAM sticks. Push the metal brackets carefully to release and remove the RAM stick .
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  8. Repeat the previous step for removing the other RAM stick. Repeat the previous step for removing the other RAM stick.
    • Repeat the previous step for removing the other RAM stick.
  9. Using a Phillips #00, remove the four screws.
    • Using a Phillips #00, remove the four screws.
  10. Using a Phillips #00 screwdriver, remove the screws. Using a Phillips #00 screwdriver, remove the screws.
  11. Use a plastic opening tool around the entire edge.
    • Use a plastic opening tool around the entire edge.
    • Separate the case from the keyboard.
  12. Ensure the laptop is face up for this step.
    • Ensure the laptop is face up for this step.
    • Gently lift the keyboard from the base of the laptop.
    • Be careful of the ribbon cables connecting the keyboard.
  13. Gently tug the ribbon cables free from their slots.
    • Gently tug the ribbon cables free from their slots.
  14. Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop. Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
    • Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
  15. Using a plastic opening tool, separate the optical drive from the laptop frame.
    • Using a plastic opening tool, separate the optical drive from the laptop frame.
    • Be careful to leverage the plastic opening tool against the frame and not the motherboard as this may cause damage.
  16. Remove the optical drive by sliding it out from the case.
    • Remove the optical drive by sliding it out from the case.
结论
Josiah Allard
于2018年10月26日注册
705 信誉积分
创作了6篇指南
团队
UMass Dartmouth, Team S2-G8, Peak Fall 2018 UMass Dartmouth, Team S2-G8, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G8
3 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 64
