跳转到主内容
Asus U56E-BBL6 Motherboard Replacement
你所需要的
  1. Asus U56E-BBL6 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure you unplugged the laptop before you begin the replacement process.
    • Locate the battery locking tabs on the upper right and left corner.
    • Press the tabs in towards each other.
  2. Asus U56E-BBL6 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pull the battery outwards to remove it.
  3. Asus U56E-BBL6 Motherboard Replacement, Back Panel: 步骤 3 中的图像 1,2 Asus U56E-BBL6 Motherboard Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the screws.
  4. Asus U56E-BBL6 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift backplate and remove from the case.
  5. Asus U56E-BBL6 Motherboard Replacement, RAM: 步骤 5 中的图像 1,1
    • Once inside the panel, locate your RAM sticks.
  6. Asus U56E-BBL6 Motherboard Replacement: 步骤 6 中的图像 1,2 Asus U56E-BBL6 Motherboard Replacement: 步骤 6 中的图像 2,2
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  7. Asus U56E-BBL6 Motherboard Replacement: 步骤 7 中的图像 1,2 Asus U56E-BBL6 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Repeat the previous step for removing the other RAM stick.
  8. Asus U56E-BBL6 Motherboard Replacement, Keyboard: 步骤 8 中的图像 1,1
    • Using a Phillips #00, remove the four screws.
  9. Asus U56E-BBL6 Motherboard Replacement: 步骤 9 中的图像 1,2 Asus U56E-BBL6 Motherboard Replacement: 步骤 9 中的图像 2,2
  10. Asus U56E-BBL6 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Use a plastic opening tool around the entire edge.
    • Separate the case from the keyboard.
  11. Asus U56E-BBL6 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Ensure the laptop is face up for this step.
    • Gently lift the keyboard from the base of the laptop.
    • Be careful of the ribbon cables connecting the keyboard.
  12. Asus U56E-BBL6 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Gently tug the ribbon cables free from their slots.
  13. Asus U56E-BBL6 Motherboard Replacement: 步骤 13 中的图像 1,2 Asus U56E-BBL6 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
  14. Asus U56E-BBL6 Motherboard Replacement, Optical Drive: 步骤 14 中的图像 1,1
    • Using a plastic opening tool, separate the optical drive from the laptop frame.
    • Be careful to leverage the plastic opening tool against the frame and not the motherboard as this may cause damage.
  15. Asus U56E-BBL6 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove the optical drive by sliding it out from the case.
  16. Asus U56E-BBL6 Motherboard Replacement, Motherboard: 步骤 16 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the three screws.
  17. Asus U56E-BBL6 Motherboard Replacement: 步骤 17 中的图像 1,3 Asus U56E-BBL6 Motherboard Replacement: 步骤 17 中的图像 2,3 Asus U56E-BBL6 Motherboard Replacement: 步骤 17 中的图像 3,3
    • Lift up the ribbon cable connector on the bottom right corner.
    • Gently pry the cable away from the connection.
  18. Asus U56E-BBL6 Motherboard Replacement: 步骤 18 中的图像 1,2 Asus U56E-BBL6 Motherboard Replacement: 步骤 18 中的图像 2,2
    • Remove the 4 pronged connection on the bottom right corner of the motherboard.
  19. Asus U56E-BBL6 Motherboard Replacement: 步骤 19 中的图像 1,2 Asus U56E-BBL6 Motherboard Replacement: 步骤 19 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the two screws.
    • Holding the board firmly with two fingers, pull outward, disconnecting it from the contacts.
  20. Asus U56E-BBL6 Motherboard Replacement: 步骤 20 中的图像 1,1
    • Repeat the previous step and remove the two wired connection next to the card.
  21. Asus U56E-BBL6 Motherboard Replacement: 步骤 21 中的图像 1,2 Asus U56E-BBL6 Motherboard Replacement: 步骤 21 中的图像 2,2
    • Remove the cable at the top left of the motherboard.
    • This cable is held in by a magnetic connection. Be sure to lift up and away when disconnecting.
  22. Asus U56E-BBL6 Motherboard Replacement: 步骤 22 中的图像 1,2 Asus U56E-BBL6 Motherboard Replacement: 步骤 22 中的图像 2,2
    • Using both hands, lift the motherboard up and out from the case
结论
另外一个人完成了本指南。
Josiah Allard
于10/26/18注册
733 声望
创作了6篇指南
团队
UMass Dartmouth, Team S2-G8, Peak Fall 2018 UMass Dartmouth, Team S2-G8, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G8
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 602
