跳转到主内容
Asus U56E-BBL6 Keyboard Replacement
你所需要的
  1. Asus U56E-BBL6 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure you unplugged the laptop before you begin the replacement process.
    • Locate the battery locking tabs on the upper right and left corner.
    • Press the tabs in towards each other.
  2. Asus U56E-BBL6 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Pull the battery outwards to remove it.
  3. Asus U56E-BBL6 Keyboard Replacement, Back Panel: 步骤 3 中的图像 1,2 Asus U56E-BBL6 Keyboard Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the screws.
  4. Asus U56E-BBL6 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Lift backplate and remove from the case.
  5. Asus U56E-BBL6 Keyboard Replacement, RAM: 步骤 5 中的图像 1,1
    • Once inside the panel, locate your RAM sticks.
  6. Asus U56E-BBL6 Keyboard Replacement: 步骤 6 中的图像 1,2 Asus U56E-BBL6 Keyboard Replacement: 步骤 6 中的图像 2,2
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  7. Asus U56E-BBL6 Keyboard Replacement: 步骤 7 中的图像 1,2 Asus U56E-BBL6 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Repeat the previous step for removing the other RAM stick.
  8. Asus U56E-BBL6 Keyboard Replacement, Keyboard: 步骤 8 中的图像 1,1
    • Using a Phillips #00, remove the four screws.
  9. Asus U56E-BBL6 Keyboard Replacement: 步骤 9 中的图像 1,2 Asus U56E-BBL6 Keyboard Replacement: 步骤 9 中的图像 2,2
  10. Asus U56E-BBL6 Keyboard Replacement: 步骤 10 中的图像 1,1
    • Use a plastic opening tool around the entire edge.
    • Separate the case from the keyboard.
  11. Asus U56E-BBL6 Keyboard Replacement: 步骤 11 中的图像 1,1
    • Ensure the laptop is face up for this step.
    • Gently lift the keyboard from the base of the laptop.
    • Be careful of the ribbon cables connecting the keyboard.
  12. Asus U56E-BBL6 Keyboard Replacement: 步骤 12 中的图像 1,1
    • Gently tug the ribbon cables free from their slots.
  13. Asus U56E-BBL6 Keyboard Replacement: 步骤 13 中的图像 1,2 Asus U56E-BBL6 Keyboard Replacement: 步骤 13 中的图像 2,2
    • Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
结论
Josiah Allard
于10/26/18注册
733 声望
创作了6篇指南
团队
UMass Dartmouth, Team S2-G8, Peak Fall 2018 UMass Dartmouth, Team S2-G8, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G8
3 名成员
创作了6篇指南
2条评论
The Keyboard still has to be removed from the Top Case! Your not done yet!
philw395 - 回复
I removed the Keyboard from the Top Case and replaced the Keyboard. It wasn’t too bad with my Heat Gun and all-in-one painters tool…yes you heard right, my handy dandy painters tool that has served me well for years. Anyway, the only problem area taking the Keyboard out and snapping it back in (if you want to call it that) was by the DVD Player. Good Luck!
philw395 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 761
