简介
This guide will teach you how to remove and replace the ports (USB/Audio Jack/Microphone Jack/E-SATA) of your Asus U50 Series laptop. You may want to replace these ports if any of them are unresponsive or not working. For example, if you were to insert multiple USBs in the same port and the computer was not recognizing any of them, this is a sign that a replacement is needed. Please note that all ports are on the same panel and must all be removed as one. After that, you may individually work on whichever one needs replacement.
BE CAREFUL when conducting this repair, as there are many loose screws that can easily be lost. Also, there are many bundles of wires which can easily be damaged if they are forcefully and carelessly removed. Lastly, make sure all your components are safely set down and not dropped, as this can cause long term damage.
你所需要的
Turn the laptop over so the bottom is facing up.
Slide the two tabs on the bottom of the laptop toward the edges of laptop.
Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
Insert one of the pry tools under a top corner and the other tool under the side of the same corner. Make sure to get under the metal of the keyboard, not just the first layer of plastic. Then pry the corner down and out from under the little overhang its sitting under.
Next, slide the pry tool on the top over to the next overhang and insert the second tool on the other side. Push down and pry out the keyboard.
Repeat the same process all the way down to the opposite corner.
Push back on the silver clips shown in the picture until you hear/feel a pop.
Remove the six screws from the outer lower case.
Remove the four screws from the hinges.
Remove the three screws on the inner lower case.
Remove the three screws from the optical drive area.
