跳转到主内容
Asus U50F-RBBAG05 Optical Drive Replacement
你所需要的
  1. Asus U50F-RBBAG05 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over so the bottom is facing up.
    • Slide the two tabs on the bottom of the laptop toward the edges of laptop.
    • Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
    • You will have to hold the right tab to the right to keep the slot unlocked while removing the battery.
  2. Asus U50F-RBBAG05 Optical Drive Replacement: 步骤 2 中的图像 1,2 Asus U50F-RBBAG05 Optical Drive Replacement: 步骤 2 中的图像 2,2
    • Hold down the tab on the right side, then begin sliding the battery out.
    • Remove the old battery.
    • Next, insert the new battery into the empty slot. Release the right tab to begin locking the new battery into place. Slide the left tab to the right to completely lock the battery into the slot. The red that was showing near the left tab should be gone. This signifies that the battery is locked into place.
  3. Asus U50F-RBBAG05 Optical Drive Replacement, Underpanel: 步骤 3 中的图像 1,1
    • Remove the six screws using a Phillips #1 screwdriver.
  4. Asus U50F-RBBAG05 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Pry the lower panel up with your fingernail or a spudger.
  5. Asus U50F-RBBAG05 Optical Drive Replacement: 步骤 5 中的图像 1,2 Asus U50F-RBBAG05 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Lift up on the panel and remove it.
  6. Asus U50F-RBBAG05 Optical Drive Replacement, Optical Drive: 步骤 6 中的图像 1,1
    • Remove the single screw.
  7. Asus U50F-RBBAG05 Optical Drive Replacement: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to push the drive out from the back.
  8. Asus U50F-RBBAG05 Optical Drive Replacement: 步骤 8 中的图像 1,2 Asus U50F-RBBAG05 Optical Drive Replacement: 步骤 8 中的图像 2,2
    • Pull the drive out and remove completely.
    • When reassembling the drive, lay the laptop with the base towards the floor. Then, push the drive all the way in. Otherwise, the drive will become stuck and be difficult to reassemble.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 135
