跳转到主内容
加入维修社区 - 创建账户
Asus Transformer T100 Power Button Replacement
你所需要的
    1. Asus Transformer T100 Power Button Replacement, Rear Cover: 步骤 1 中的图像 1,2 Asus Transformer T100 Power Button Replacement, Rear Cover: 步骤 1 中的图像 2,2
      • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
      • Remove the tablet by lifting up.
      询问修复机器人
      添加评论
    2. Asus Transformer T100 Power Button Replacement: 步骤 2 中的图像 1,2 Asus Transformer T100 Power Button Replacement: 步骤 2 中的图像 2,2
      • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
      • With a little force, you will feel the clips release.
      添加评论
    3. Asus Transformer T100 Power Button Replacement: 步骤 3 中的图像 1,1
      • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
      • Do not break these clips; otherwise, the screen will become less secure.
      询问修复机器人
      添加评论
    4. Asus Transformer T100 Power Button Replacement: 步骤 4 中的图像 1,2 Asus Transformer T100 Power Button Replacement: 步骤 4 中的图像 2,2
      • Remove the rear casing.
      询问修复机器人
      添加评论
    1. Asus Transformer T100 Power Button Replacement, Power Button: 步骤 5 中的图像 1,2 Asus Transformer T100 Power Button Replacement, Power Button: 步骤 5 中的图像 2,2
      • Using a flathead screwdriver, pry the button connection up.
      • There will be some resistance. Slowly increase the pressure until the button pops off.
      添加评论
结论
Use a small amount of epoxy or other adhesive to attach the new button.
取消:我没有完成这个指南。
10等其他人完成本指南。
Taylor Pantiga
于04/14/14注册
1,629 声望
创作了6篇指南
团队
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G31
3 名成员
创作了42篇指南
4指南评论
Where can you get a button?
dsmit26 - 回复 分享
Anyone have a link to get the button?
Seb bar - 回复 分享
hi
i got a major problem ....mine is tf300t and when i got the cover out the power button came out with it what should i do i can't reattach it with my bare hands plsss help me !!!!
kiko - 回复 分享
The asus computer fell, well the screen took a beating, touch no longer works and sometimes the tablet senses as if it were touched making it difficult to perform tasks clicking etc.
The keyboard is partially working. The computer was still operation like for reading and watching to some extent
The battery ran out and found out that the power button isn't clicking really, no feedback.
Apart from the obvious problems, I'd like to first turn the tablet on after charging (have some files on it ti download). From the depiction is there a chance popping the tablet open would be of assistance? Could the screen though fall apart following opening it up? Any suggestions? Your assistance is most appreciated
Thank you
100 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 73
总计 24,737
