本指南有最近更改,您可查看未经巡查的最新版本。
简介
The motherboard of the device is the tablet's main processing unit. To reach it, the plastic backing, battery, and camera must be removed.
你所需要的
Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
Remove the tablet by lifting up.
17等其他人完成本指南。
11条评论
As the previous comment stated (but only for step 7), ALL the connection apparatus have a white "flip" side (for STEP 7, 9, 17 and 19). Instead of struggling (like I did first), simply lift up the white side with your nail and gently remove the ribbons. Also, it is not necessary to entirely remove the battery (STEP 13) to carefully disconnect the cables. Thanks for for the tutorial though!
Hey! I have the T100TA. Super happy with it, but it's a bit older and only has 1gb of RAM. Is it possible to put the board of the T100(which has 2gb of RAM) into it? I assume size is the same, but are the connections? Thanks!
I have “downgraded” my T100TAM by installing a motherboard from the T100 (because I couldn’t find a T100TAM motherboard). So the other way around should also be possible.
I replaced the motherboard. Did everthing right. But it didn't turned on.
Is there any way to start up the motherboard first time?
mauroabram - 回复
Where is the hard drive located on these? Is it on the board and can it be swapped out? I have data on one which is locked and the device won’t boot to anything at all so stuck!
