简介
This is a guide how to change the Digitizer screen on an asus T-100 transformer book.
你所需要的
In order to get the back cover off, use a tool you are familiar with to pry it open carefully.
Insert a pick, and slowly go around the edge of the tablet to loosen the back shield
Use a Phillips #1 screw driver to loosen all the screws.
Make a system to organize the screws, since they have different sizes.
Loosen the tape of the battery connection.
Be careful you don't break the wires. They can seem stuck and hard loosen up.
Separate the cable from the connecter.
Under the tape is there a connection we have to take off, plus another screw.
As in step 9 later there is a white strip under the black sticky sponge that lifts to allow the ribbon tape to come out easily.
Next we have to take out the speaker because it has a connection on the motherboard.
In order to get the speaker out you have to lift up the motherboard just a little bit. You can use your finger or any other tool you feel familiar using.
Next step is a little tricky. We have to disconnect the digitizer. ! Be very careful you don't ruin the closing mechanism. Simply pull back and pull slowly until the connection comes out.
We are now ready to take out the motherboard. This is done by following all the steps to this point.
Carefully lift the board in both ends or in 2 of the 4 corners and slowly lift it off to the side.
Next step is to take out the LCD. Depending on the model # of your device screws can be placed different corners.
Take out the screws and lift out the LCD screen
The last step is to separate the plastic frame from the old Digitizer glass.
I recommend using a heat gun to heat up the glue and then easily separate the old digitizer.
You are now ready to put your new digitizer on the plastic frame and assemble the T-100.
30等其他人完成本指南。
27条评论
Thanks so much for the guide, it was a long process but we'll worth it.
Cody Smith - 回复
Hope it was helpful and that it was detailed enough :) thank you for looking :)
Great guide, however I would make one small addition. In the final instructions just a little warning about keeping the heat very low, similar to a hair dryer and take your time. I discovered the hard way that the plastic bezel has quite a low melt/warp temp and I effectively ruined one of the two I was repairing. Sourcing a new digitizer with bezel or bezel alone is proving to be incredibly challenging.
Thank you for the heads up I will edit that as soon as possible
Please, can you give the clearer instructions about 3 different screw sizes, where are they locations. I mixed them up...
