跳转到主内容
Asus Transformer T100 Front Facing Camera Board Replacement
你所需要的
  1. Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: 步骤 1 中的图像 1,2 Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: 步骤 1 中的图像 2,2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 2 中的图像 1,2 Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 2 中的图像 2,2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 3 中的图像 1,1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 4 中的图像 1,2 Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 4 中的图像 2,2
    • Remove the rear casing.
  5. Asus Transformer T100 Front Facing Camera Board Replacement, Front Facing Camera Board: 步骤 5 中的图像 1,1
    • The camera board is located in the red square in this image.
  6. Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 6 中的图像 1,2 Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 6 中的图像 2,2
    • Remove the two screws on the camera board using a Phillips #1 Screwdriver.
  7. Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 7 中的图像 1,3 Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 7 中的图像 2,3 Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 7 中的图像 3,3
    • Lift up the power button cable retention clip on the motherboard and pull the cable out.
  8. Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 8 中的图像 1,2 Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 8 中的图像 2,2
    • On the camera connection apparatus, locate the silver tape that connects to the tablet.
    • Peel the silver tape off of the tablet on both sides of the connection apparatus.
    • If this step has been completed correctly, the camera board should be loose, with the tape still attached to the connection apparatus.
  9. Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 9 中的图像 1,3 Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 9 中的图像 2,3 Asus Transformer T100 Front Facing Camera Board Replacement: 步骤 9 中的图像 3,3
    • Gently pull the Orange ribbon cable out of the connection port.
    • This port has no clip. The orange apparatus should slide out with a small tug.
结论
2等其他人完成本指南。
Taylor Pantiga
于04/14/14注册
1,596 声望
创作了6篇指南
团队
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G31
3 名成员
创作了6篇指南
一条评论
Hello, can you please tell a manufacturer of the camera (is it writter somethere on it)?
Alexius Hoopakele Ae - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 3,659
