本指南有最近更改,您可查看未经巡查的最新版本。
简介
The battery is located inside the tablet part of the device. The plastic backing must be removed before the battery can be accessed.
你所需要的
Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
Remove the tablet by lifting up.
68等其他人完成本指南。
22条评论
So I switched out my screen for it and its not turning on and I checked it everything was correctly place, but my Asus transformer was dead before hand so I tried charging it, and it wasn't charging, so I checked it and it seems the battery wire harness is loose enough to come off, is it possible to fix that?
Hi christian! How did you solve this problem? That happened to me too...
Part number is C12N1320. They are available from a variety of sources.
