跳转到主内容
Asus Transformer Pad Infinity LCD Display Replacement
你所需要的
  1. Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: 步骤 1 中的图像 1,3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: 步骤 1 中的图像 2,3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: 步骤 1 中的图像 3,3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Asus Transformer Pad Infinity LCD Display Replacement: 步骤 2 中的图像 1,1
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
  3. Asus Transformer Pad Infinity LCD Display Replacement: 步骤 3 中的图像 1,1
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
  4. Asus Transformer Pad Infinity LCD Display Replacement: 步骤 4 中的图像 1,1
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
  5. Asus Transformer Pad Infinity LCD Display Replacement: 步骤 5 中的图像 1,1
    • Once removed, replace the LCD display back onto the glass screen (the new screen may or may not have new adhesive depending on where you got it.
    • If it doesn’t, make sure you secure it with the screws safely).
结论
Allison Poh
于10/20/15注册
549 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G1
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,231
