跳转到主内容
Asus Transformer Pad Infinity Charging Port Replacement
你所需要的
  1. Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,2 Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: 步骤 1 中的图像 2,2
    • Take off the screen and the big motherboard.
  2. Asus Transformer Pad Infinity Charging Port Replacement: 步骤 2 中的图像 1,3 Asus Transformer Pad Infinity Charging Port Replacement: 步骤 2 中的图像 2,3 Asus Transformer Pad Infinity Charging Port Replacement: 步骤 2 中的图像 3,3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  3. Asus Transformer Pad Infinity Charging Port Replacement: 步骤 3 中的图像 1,1
    • Flip up the piece securing the ribbon to the big motherboard and remove the ribbon from the motherboard.
    • Note: This will have tape covering it, make sure not to cut the ribbon or scratch any other parts if you are looking to preserve these things.
  4. Asus Transformer Pad Infinity Charging Port Replacement: 步骤 4 中的图像 1,1
    • Remove the two screws holding the actual port, that goes to the outside of the device, in. This piece will be connected to the case.
  5. Asus Transformer Pad Infinity Charging Port Replacement: 步骤 5 中的图像 1,1
    • Once removing the damaged charging port, put in your new part and reassemble the device and check if the new charging port works.
结论
另外一个人完成了本指南。
Allison Poh
于10/20/15注册
549 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G1
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,257
