跳转到主内容
Asus Transformer Flip Book TP200S WiFi Card Replacement
你所需要的
  1. Asus Transformer Flip Book TP200S WiFi Card Replacement, Battery: 步骤 1 中的图像 1,2 Asus Transformer Flip Book TP200S WiFi Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Asus Transformer Flip Book TP200S WiFi Card Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Asus Transformer Flip Book TP200S WiFi Card Replacement: 步骤 3 中的图像 1,1
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  4. Asus Transformer Flip Book TP200S WiFi Card Replacement: 步骤 4 中的图像 1,2 Asus Transformer Flip Book TP200S WiFi Card Replacement: 步骤 4 中的图像 2,2
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • Gently remove the Wifi cables hooked to the rim of the battery
    • Remove the battery
  5. Asus Transformer Flip Book TP200S WiFi Card Replacement, WiFi Card: 步骤 5 中的图像 1,1
    • The WiFi card will be covered by tape and attached to the motherboard.
    • Remove the tape from the WiFi card.
  6. Asus Transformer Flip Book TP200S WiFi Card Replacement: 步骤 6 中的图像 1,3 Asus Transformer Flip Book TP200S WiFi Card Replacement: 步骤 6 中的图像 2,3 Asus Transformer Flip Book TP200S WiFi Card Replacement: 步骤 6 中的图像 3,3
    • Unscrew the WiFi card with a JIS #000 screwdriver.
    • Remove the motherboard connection from the WiFi card with tweezers.
    • Pull out the WiFi card.
结论
另外一个人完成了本指南。
Alejandro Lopez
于02/15/18注册
662 声望
创作了5篇指南
团队
USF Tampa, Team S17-G2, Boczar Spring 2018 USF Tampa, Team S17-G2, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 785
