跳转到主内容
Asus Transformer Flip Book TP200S Motherboard Replacement
你所需要的
  1. Asus Transformer Flip Book TP200S Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Asus Transformer Flip Book TP200S Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Asus Transformer Flip Book TP200S Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Asus Transformer Flip Book TP200S Motherboard Replacement: 步骤 3 中的图像 1,1
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  4. Asus Transformer Flip Book TP200S Motherboard Replacement: 步骤 4 中的图像 1,2 Asus Transformer Flip Book TP200S Motherboard Replacement: 步骤 4 中的图像 2,2
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • Gently remove the Wifi cables hooked to the rim of the battery
    • Remove the battery
  5. Asus Transformer Flip Book TP200S Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Asus Transformer Flip Book TP200S Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Asus Transformer Flip Book TP200S Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
    • The motherboard has various components connected to it that you will need to disconnect to replace.
    • Disconnect the components from the motherboard with tweezers. Refer to the images for which components need to be removed.
    • The connections highlighted in yellow are easily removed by lightly pulling, If there is tape on it, simply remove the tape.
    • The connections in red require you to lift up the white latch securing these connections. The white latch lifts upward easily, afterwards simply slide out the connecting cable.
    • The connection in orange is similar to the connections in red, except the black part is the latch. Like before, flip it up and slide out the cable.
  6. Asus Transformer Flip Book TP200S Motherboard Replacement: 步骤 6 中的图像 1,3 Asus Transformer Flip Book TP200S Motherboard Replacement: 步骤 6 中的图像 2,3 Asus Transformer Flip Book TP200S Motherboard Replacement: 步骤 6 中的图像 3,3
    • Unscrew the 3mm and 6mm motherboard screws from the device using a J000 screwdriver.
    • Remove the motherboard from the device.
结论
另外一个人完成了本指南。
Alejandro Lopez
于02/15/18注册
662 声望
创作了5篇指南
团队
USF Tampa, Team S17-G2, Boczar Spring 2018 USF Tampa, Team S17-G2, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G2
3 名成员
创作了6篇指南
一条评论
where can I get the board to buy??
Argent Logan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 2,614
