跳转到主内容
Asus Transformer Flip Book TP200S LCD Screen Replacement
你所需要的
  1. Asus Transformer Flip Book TP200S LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 Asus Transformer Flip Book TP200S LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Asus Transformer Flip Book TP200S LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Asus Transformer Flip Book TP200S LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  4. Asus Transformer Flip Book TP200S LCD Screen Replacement: 步骤 4 中的图像 1,2 Asus Transformer Flip Book TP200S LCD Screen Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • Gently remove the Wifi cables hooked to the rim of the battery
    • Remove the battery
  5. Asus Transformer Flip Book TP200S LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 1,2 Asus Transformer Flip Book TP200S LCD Screen Replacement, LCD Screen: 步骤 5 中的图像 2,2
    • Open your flip book so that the screen faces towards you. You will notice 2 rubber pads at the base of the screen.
    • Using a metal spudger, lift the rubber pads off to find 2 screen 3mm screws. Unscrew these 3mm screw with a phillips head J000 screwdriver.
  6. Asus Transformer Flip Book TP200S LCD Screen Replacement: 步骤 6 中的图像 1,2 Asus Transformer Flip Book TP200S LCD Screen Replacement: 步骤 6 中的图像 2,2
    • After removing the screws, use the metal spudger to gentle pry open the screen casing from the flip book casing.
  7. Asus Transformer Flip Book TP200S LCD Screen Replacement: 步骤 7 中的图像 1,2 Asus Transformer Flip Book TP200S LCD Screen Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Gently remove all the connections and tape you see attached to the screen with tweezers.
  8. Asus Transformer Flip Book TP200S LCD Screen Replacement: 步骤 8 中的图像 1,1
    • After all connections have been removed, use the metal spudger and pry the screen itself from the screen casing.
    • Caution: The screen is glued to the screen casing with adhesive so you will need to exert some force to get the screen off. This will likely damage your old screen permanently. Be certain you have a replacement readily available before you engage in this step.
    • You will not need to reapply the adhesive.
结论
另外一个人完成了本指南。
Alejandro Lopez
于02/15/18注册
662 声望
创作了5篇指南
团队
USF Tampa, Team S17-G2, Boczar Spring 2018 USF Tampa, Team S17-G2, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G2
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,922
