跳转到主内容
Asus Transformer Flip Book TP200S IO Board Replacement
你所需要的
  1. Asus Transformer Flip Book TP200S IO Board Replacement, Battery: 步骤 1 中的图像 1,2 Asus Transformer Flip Book TP200S IO Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Asus Transformer Flip Book TP200S IO Board Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Asus Transformer Flip Book TP200S IO Board Replacement: 步骤 3 中的图像 1,1
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  4. Asus Transformer Flip Book TP200S IO Board Replacement: 步骤 4 中的图像 1,2 Asus Transformer Flip Book TP200S IO Board Replacement: 步骤 4 中的图像 2,2
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • Gently remove the Wifi cables hooked to the rim of the battery
    • Remove the battery
  5. Asus Transformer Flip Book TP200S IO Board Replacement, IO Board: 步骤 5 中的图像 1,2 Asus Transformer Flip Book TP200S IO Board Replacement, IO Board: 步骤 5 中的图像 2,2
    • The IO Board will be the section of circuitry to the left. It's held down by a couple of 3mm and 6mm screws and some device connections.
    • Unscrew the 3mm and 6mm screws on the IO Board with a phillips head J000 screwdriver.
  6. Asus Transformer Flip Book TP200S IO Board Replacement: 步骤 6 中的图像 1,3 Asus Transformer Flip Book TP200S IO Board Replacement: 步骤 6 中的图像 2,3 Asus Transformer Flip Book TP200S IO Board Replacement: 步骤 6 中的图像 3,3
    • After unscrewing, gently unplug all the connections to the IO Board with tweezers. We have highlighted where these connections are located in our images.
  7. Asus Transformer Flip Book TP200S IO Board Replacement: 步骤 7 中的图像 1,2 Asus Transformer Flip Book TP200S IO Board Replacement: 步骤 7 中的图像 2,2
    • Remove the final connections from the IO board with tweezers.
结论
Alejandro Lopez
于02/15/18注册
662 声望
创作了5篇指南
团队
USF Tampa, Team S17-G2, Boczar Spring 2018 USF Tampa, Team S17-G2, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 637
