跳转到主内容
Asus Transformer Book T100TAR Front Camera Replacement
你所需要的
  1. Asus Transformer Book T100TAR Front Camera Replacement, Front Camera: 步骤 1 中的图像 1,2 Asus Transformer Book T100TAR Front Camera Replacement, Front Camera: 步骤 1 中的图像 2,2
    • Detach and separate the screen from the keyboard by pressing the silver release button at the base of the tablet.
  2. Asus Transformer Book T100TAR Front Camera Replacement: 步骤 2 中的图像 1,1
    • Take the metal spudger and insert it into the seam of the rear cover casing and gently pry upwards.
    • If done correctly, you should feel the clips release.
    • Ensure that all the clips are released by sliding the spudger along the four edges of the tablet.
    • Do not force the clips to release. This will cause them to break, and if broken, the screen will become loose. Open the rear cover gently and with caution.
  3. Asus Transformer Book T100TAR Front Camera Replacement: 步骤 3 中的图像 1,1
    • Take off the rear case
  4. Asus Transformer Book T100TAR Front Camera Replacement: 步骤 4 中的图像 1,1
    • Unscrew two 5mm screws from the camera board using a Phillips #0 Screwdriver.
  5. Asus Transformer Book T100TAR Front Camera Replacement: 步骤 5 中的图像 1,1
    • Using a plastic opening tool, lift the white tab holding the power button cable, located on the camera board and pull out the cable strip.
  6. Asus Transformer Book T100TAR Front Camera Replacement: 步骤 6 中的图像 1,1
    • Also using the plastic opening tool, gently lift up and remove the large black strip connecting the camera board to the motherboard.
  7. Asus Transformer Book T100TAR Front Camera Replacement: 步骤 7 中的图像 1,1
    • Remove the camera board.
结论
团队
USF Tampa, Team 6-1, Remmell Fall 2016 USF Tampa, Team 6-1, Remmell Fall 2016 的会员
USFT-REMMELL-F16S6G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 11
总计 419
