跳转到主内容
Asus Transformer Book T100TAM-C1 USB Input Replacement
你所需要的
  1. Asus Transformer Book T100TAM-C1 USB Input Replacement, USB Input: 步骤 1 中的图像 1,1
    • Remove the tablet portion of the device from the keyboard by pushing on the silver button located at the base of the tablet and lifting up on the tablet.
  2. Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to remove both of the top corner pads.
  3. Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 3 中的图像 1,2 Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 3 中的图像 2,2
    • Remove two 5mm Phillips #0 screws on the top corners.
    • Remove four 2.5mm Phillips #0 screws on the top corners.
  4. Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 4 中的图像 1,1
    • Use the pick and pry apart the keyboard.
  5. Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 5 中的图像 1,1
    • Use the size 0 Phillips screwdriver and remove the nine screws from the back panel. The four you need to remove across the top are 3mm and the four across the bottom are 2.5mm.
    • The screw in the top right, shown where the screwdriver is, is a 5mm screw.
  6. Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 6 中的图像 1,2 Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers and remove the black tape from the back panel.
  7. Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 7 中的图像 1,1
    • Remove the metal back panel from the keyboard.
  8. Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 8 中的图像 1,3 Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 8 中的图像 2,3 Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 8 中的图像 3,3
    • Flip the connectors back to release the wires
    • Take the white tab and gently pull it to the right in order to release the connecting piece.
  9. Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 9 中的图像 1,1
    • Remove the screw from the green plate.
    • Once all of the screws are out, remove the plate.
  10. Asus Transformer Book T100TAM-C1 USB Input Replacement: 步骤 10 中的图像 1,1
    • Place soldering tool on each of the four connecting pieces in the corner until each becomes unattached.
    • Remove old USB input and replace with the new one.
结论
Brody Moore
于09/06/18注册
807 声望
创作了7篇指南
团队
Ohio State, Team S1-G2, Whitney Fall 2018 Ohio State, Team S1-G2, Whitney Fall 2018 的会员
OSU-WHITNEY-F18S1G2
2 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 285
