跳转到主内容
Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement
你所需要的
  1. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Back Panel: 步骤 1 中的图像 1,2 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
  2. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: 步骤 2 中的图像 1,3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: 步骤 2 中的图像 2,3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: 步骤 2 中的图像 3,3
    • Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device.
    • If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
  3. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: 步骤 3 中的图像 1,2 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: 步骤 3 中的图像 2,2
    • Pull the rear panel and the display screen away from each other.
  4. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Battery: 步骤 4 中的图像 1,3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Battery: 步骤 4 中的图像 2,3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Battery: 步骤 4 中的图像 3,3
    • Using the spudger, gently press on the black button on the plug port to release the battery from the plug.
  5. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: 步骤 5 中的图像 1,2 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the battery from the device.
  6. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Using the tweezers, disconnect the black clip.
  7. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: 步骤 7 中的图像 1,3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: 步骤 7 中的图像 2,3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: 步骤 7 中的图像 3,3
    • Use the Phillips #000 Screwdriver to unscrew the 3mm Phillips head screws on the right and left corners of the speaker.
    • Use the magnetic pad to keep track of your screws while working.
  8. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: 步骤 8 中的图像 1,1
    • Remove the speaker from the device.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 197
