跳转到主内容
Asus Tablet MeMO Pad 7 ME7000C Battery Replacement
你所需要的
  1. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
  2. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 步骤 2 中的图像 1,3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 步骤 2 中的图像 2,3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 步骤 2 中的图像 3,3
    • Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device.
    • If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
  3. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 步骤 3 中的图像 1,2 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 步骤 3 中的图像 2,2
    • Pull the rear panel and the display screen away from each other.
  4. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Battery: 步骤 4 中的图像 1,3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Battery: 步骤 4 中的图像 2,3 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Using the spudger, gently press on the black button on the plug port to release the battery from the plug.
  5. Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 步骤 5 中的图像 1,2 Asus Tablet MeMO Pad 7 ME7000C Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the battery from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 599
