跳转到主内容
Asus TUF Gaming FX705G Track Pad Replacement
你所需要的
  1. Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: 步骤 1 中的图像 1,2 Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Track Pad Replacement: 步骤 2 中的图像 1,2 Asus TUF Gaming FX705G Track Pad Replacement: 步骤 2 中的图像 2,2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Track Pad Replacement, Battery: 步骤 3 中的图像 1,2 Asus TUF Gaming FX705G Track Pad Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Track Pad Replacement: 步骤 4 中的图像 1,2 Asus TUF Gaming FX705G Track Pad Replacement: 步骤 4 中的图像 2,2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Track Pad Replacement, Track pad: 步骤 5 中的图像 1,2 Asus TUF Gaming FX705G Track Pad Replacement, Track pad: 步骤 5 中的图像 2,2
    • Take the ribbon wire out of the track pad.
  6. Asus TUF Gaming FX705G Track Pad Replacement: 步骤 6 中的图像 1,2 Asus TUF Gaming FX705G Track Pad Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the two screws holding the track pad in place.
  7. Asus TUF Gaming FX705G Track Pad Replacement: 步骤 7 中的图像 1,2 Asus TUF Gaming FX705G Track Pad Replacement: 步骤 7 中的图像 2,2
    • Take the ground wire ribbon and pry it off of the motherboard housing with tweezers.
  8. Asus TUF Gaming FX705G Track Pad Replacement: 步骤 8 中的图像 1,3 Asus TUF Gaming FX705G Track Pad Replacement: 步骤 8 中的图像 2,3 Asus TUF Gaming FX705G Track Pad Replacement: 步骤 8 中的图像 3,3
    • Use the iFixit opening tool to pry the track pad up slightly at the top and pull the latch at the top to free the track pad.
    • Slide the track pad up and out of the housing unit.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 1,834
