跳转到主内容
Asus TUF Gaming FX705G Speakers Replacement
你所需要的
  1. Asus TUF Gaming FX705G Speakers Replacement, Back Cover: 步骤 1 中的图像 1,2 Asus TUF Gaming FX705G Speakers Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Speakers Replacement: 步骤 2 中的图像 1,2 Asus TUF Gaming FX705G Speakers Replacement: 步骤 2 中的图像 2,2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Speakers Replacement, Battery: 步骤 3 中的图像 1,2 Asus TUF Gaming FX705G Speakers Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Speakers Replacement: 步骤 4 中的图像 1,2 Asus TUF Gaming FX705G Speakers Replacement: 步骤 4 中的图像 2,2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Speakers Replacement, Speakers: 步骤 5 中的图像 1,2 Asus TUF Gaming FX705G Speakers Replacement, Speakers: 步骤 5 中的图像 2,2
    • Use your fingers to lift the speaker from the housing and follow the wire path carefully, lifting the wire out of place around the base.
  6. Asus TUF Gaming FX705G Speakers Replacement: 步骤 6 中的图像 1,1
    • Repeat the removal process on the second speaker, being careful not to rip the wire.
  7. Asus TUF Gaming FX705G Speakers Replacement: 步骤 7 中的图像 1,1
    • With the second speaker removed from the track, carefully disconnect the three wires from the insert on the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 1,516
