跳转到主内容
Asus TUF Gaming FX705G Fan Replacement
你所需要的
  1. Asus TUF Gaming FX705G Fan Replacement, Back Cover: 步骤 1 中的图像 1,2 Asus TUF Gaming FX705G Fan Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Fan Replacement: 步骤 2 中的图像 1,2 Asus TUF Gaming FX705G Fan Replacement: 步骤 2 中的图像 2,2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Fan Replacement, Battery: 步骤 3 中的图像 1,2 Asus TUF Gaming FX705G Fan Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Fan Replacement: 步骤 4 中的图像 1,2 Asus TUF Gaming FX705G Fan Replacement: 步骤 4 中的图像 2,2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Fan Replacement, Fan: 步骤 5 中的图像 1,2 Asus TUF Gaming FX705G Fan Replacement, Fan: 步骤 5 中的图像 2,2
    • Remove the five Phillips #00 screws from the fan casings.
    • The left fan has three screws and the right fan has two screws.
  6. Asus TUF Gaming FX705G Fan Replacement: 步骤 6 中的图像 1,3 Asus TUF Gaming FX705G Fan Replacement: 步骤 6 中的图像 2,3 Asus TUF Gaming FX705G Fan Replacement: 步骤 6 中的图像 3,3
    • Unplug the cables that connect the fan to the motherboard.
  7. Asus TUF Gaming FX705G Fan Replacement: 步骤 7 中的图像 1,3 Asus TUF Gaming FX705G Fan Replacement: 步骤 7 中的图像 2,3 Asus TUF Gaming FX705G Fan Replacement: 步骤 7 中的图像 3,3
    • Lift the motherboard to unclip the housing clip on the back of the fan.
    • Remove the fan.
结论
15等其他人完成本指南。
3条评论
A bit nerve-racking, but got the new CPU fan installed, seems to be working fine according to armory crate. I did note that the CPU fan plug was quite stiff but I did manage to carefully wiggle it out. Anyways found your instructions very helpful especially the pics.
Thank You.
1857classic - 回复
Is it possible to change the cpu an gpu I'm a noob for sure thanks
Like to change them to make it a better pc might not be able to FX705DY
Christopher Hall - 回复
This was very helpful. Thank you
Sue Olmos - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 142
总计 15,698
