跳转到主内容
Asus TUF Gaming FX505DY Touchpad Replacement
你所需要的
  1. Asus TUF Gaming FX505DY Touchpad Replacement, Motherboard: 步骤 1 中的图像 1,3 Asus TUF Gaming FX505DY Touchpad Replacement, Motherboard: 步骤 1 中的图像 2,3 Asus TUF Gaming FX505DY Touchpad Replacement, Motherboard: 步骤 1 中的图像 3,3
    • With a Phillips 0-bit screwdriver, remove eight 5.0 mm screws on the silver brackets
    • With a Phillips 0-bit screwdriver, remove two 5.0 mm screws holding the edge of the fans in place
  2. Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 2 中的图像 1,3 Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 2 中的图像 2,3 Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 2 中的图像 3,3
    • Gently remove all power cables connecting the fans to the motherboard.
    • Once all cables and screws are removed, carefully lift up and remove the fans and heat sink
  3. Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 3 中的图像 1,2 Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 3 中的图像 2,2
    • With a Phillips 0-bit screwdriver, unscrew four 5.0 mm screws.
    • Disconnect the primary connector cable located at the bottom left and carefully remove the module.
  4. Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 4 中的图像 1,3 Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 4 中的图像 2,3 Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 4 中的图像 3,3
    • Removing the ram, push down unto the ram and move the metal locking tabs to the side by lifting upward slightly then moving each to their outside.
    • Pull the ram out toward the angle when the ram is sticking up at an angle when released.
  5. Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 5 中的图像 1,2 Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 5 中的图像 2,2
    • With a Phillips 0-bit screwdriver, unscrew four 5.0 mm top screws holding the hard drive in place.
    • Pinch the top left corner with your finger and slide the harddrive out of its casing.
  6. Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 6 中的图像 1,2 Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 6 中的图像 2,2
    • With a Phillips 0-bit screwdriver, unscrew two 5.0 mm screws holding SSD down to the motherboard on the right side of the board
    • Slide module out of protective casing to remove piece.
  7. Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 7 中的图像 1,3 Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 7 中的图像 2,3 Asus TUF Gaming FX505DY Touchpad Replacement: 步骤 7 中的图像 3,3
    • With a size 0 Phillips screwdriver, unscrew three center 5 mm screws securing the board in place.
    • Carefully lift the board and place in a safe area.
  8. Asus TUF Gaming FX505DY Touchpad Replacement, Touchpad: 步骤 8 中的图像 1,3 Asus TUF Gaming FX505DY Touchpad Replacement, Touchpad: 步骤 8 中的图像 2,3 Asus TUF Gaming FX505DY Touchpad Replacement, Touchpad: 步骤 8 中的图像 3,3
    • With a size 0 Phillips screwdriver, unscrew two 5 mm screws holding the trackpad in place located at the bottom of the trackpad.
    • Carefully unclip the connector base to remove the two touchpad cables.
    • Remove the trackpad by sliding forward and lifting up.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 48
总计 817
